jenuary
I wanted to understand if solidworks allows to change the text "part" with another custom text, this when creating a new part.
for example when we create a new part the software proposes "part1" if we have just started the session, and increases the progressive to the next parts; If you want to change the static text "part" with another text so that it automatically proposed to me, there is a set or text file that handles this thing.
I ask because often I happen to work with more users in the same project, I then find myself having to rename the parts before assiemare everything, otherwise they create conflicts; If, however, each user has its own initial code different from the others, this problem would not exist and I could verify the assiemato as many times as I want without risk.
consider not to use the pdm or macro.. .
