isocline curves
  • Thread starter Thread starter ozwego
ozwego
Hello, girl, I need help.
Could someone of good will explain to me how3 the isocline curve command works? ?
thank you very much in advance
with nx 9, open the command select the z axis (if your model develops in height on that axis), select the faccies of the model on which you want it to be drawn your curve, select the angle (usually 0°) of a hypothetical plane that cuts your surface perpendicularly to the axis of before (z).
with nx 7.5 the interface will be different but the data to give are the same, I hope to have been useful.
