isometric graphic symbols
  • Thread starter Thread starter Warmhead
Warmhead
Good morning to all,
I ask for help to find a library of graphic symbols, used in the isometric designs of petrochemical chemical plants.
Having received from the customer the isometrics and having to decipher them, I would not like to incur gross errors.
Thank you in advance...
Well, just look for 5 minutes on the net, I found those links like this, and they're the first ones I got.
if you don't want to search in the sea magnum of the internet, just search inside the site itself.
like this old discussion for example:http://www.cad3d.it/forum1/showthread.php?t=15611look at how many beautiful pictures and useful links :d
here' from page 25 (it seems) forward there is some example at the schematic level of supportery: :smile:http://corsiadistanza.polito.it/corsi/pdf/02bghdn/lezione_piping_ed01.pdfHowever + of this I do not know exactly what to tell you, you can not have the support exactly as it will be done.
on the iso that I have seen all, and I say all the supports are indicated with a x and a number, which may postpone (this yes) to an internal coding, that is the company that will realize the support.
And in some cases I'm not really... you pass a line for where?
How hot is it?
In short, we must build an ad hoc support:wink:
in fact if to support a tube you want to use beams it will have (obviously) an international standardization that tells you to - b -w thickness of the soul etc. etc.
Just take any valid profiler.
but what, how many and how these beams are put that you can only know.
or who draws/designs the support itself in the company that will make the supports, which obviously must look around to see where can put these blessed he.
If you are in the field, or inside an oil plant, as you write at first you know the chaos of racks, machinery, beams, trenches, pillars that turn around you? :biggrin:
Therefore my advice is to address one of these specialized firms and ask them for a copy of their catalogue if they have it.
or search on the net.
