Jealousy Sheet Metal
  • Thread starter Thread starter lollone
lollone
Hello proeist brothers!! !
Does anyone know if there is a simple way to shape the jealousy on the sheets?
we use the command form: you create a part that does as a punch then, with the command forms precisely, the position and here is the "gelosia".
I would also advise you to use the punzona option and not "stampo", moreover, if you do not want to create ties with the punch itself, I would recommend you to use the copy option and not reference.
Annnnnnnnnnnnnnnnnnnnnnn! !
I found now the command excludes wall!!! !
Thank you so much!! !
but Friday is the day of the jealous, I was made the same request, I arrive randomly to look for some info on how to make a jealousy and there is a fresh day.
however for those who can serve:http://www.youtube.com/watch?v=inpryaccbmi lollone I found now the command excludes wall!!! !
How did you do that? I can't
