join point curve
  • Thread starter Thread starter Ismaele
Ismaele
Good morning, I'm ismaele and I started using autocad seriously recently...
I came across this project. from a 3d sw design, I extrapolated the part I need in 2d getting this line to points. I can't join these points in pl.
I tried the editpl command, but discard the points to join... Do you have any advice to give me or something to read?
autocad... catia... The same thing practically. do not open another thread, but ask moderators to move the discussion in the correct section
if the ends are not united will never make a unique polyline.
ok, could you kindly indicate the thread link already opened?
I don't find the thread... cmq the ends seem to me joined. How can I check this?
There is no thread. I wrote not to open a new thread, but ask moderators to move this in the correct section.
if you enlarge you will see that polylines are not united
the sketch in the starting software (solidworks?) is closed? is it well done?
to understand that attached is the situation of your polylinea with various stages of enlargement
going to correctly combine the ends that stretch of polylinea joins.
