join the walls
  • Thread starter Thread starter teo's
teo's
Hello everyone! I have the following problem: I have to build a house and I'm designing directly using the 2009 autocad architecture libraries, selecting reinforced concrete plastered. Once the outer walls are finished (for the record made in the classic 30 cm thick) they have to pass to the internal walls from 15 cm. the problem is that when I start the wall from one end to another, although the spell mode is selected, it does not go straight but always tries to take angles other than the orthogonal ones (photo1). I then try to go on property and set the rotation angle at 90° and the wall finally rewinds but, icons appear that tell me to press ctrl to move or stretch (photo2) and also if I go then to make the display in 3d or rendering the walls on which these icons appear totally disappear. Would anyone know how to tell me where I'm wrong or how to suggest the correct resolution of the problem? thanks in advance and good day!
