join two polylines
  • Thread starter Thread starter lx1127
lx1127
Hello everyone,
and apologize for the question maybe stupid but I don't go out:
I would like to generate 2 polylinese say so:
dim pline1 as acadpolyline
dim pline2 as acadpolyline
dim pline3 as acadpolyline
dim points(8) as double
points(0) = 100 points(1) = 100 points(2) = 0
points(3) = 500 points(4) = 100 points(5) = 0
points(6) = 500 points(7) = 500 points(8) = 0
set pline1 = thisdrawing.modelspace.addpolyline(points)
(2)
dim pointsb(8) as double
pointsb(0) = 100 pointsb(1) = 100 pointsb(2) = 0
pointsb(3) = 100 pointsb(4) = 500 pointsb(5) = 0
pointsb(6) = 500 pointsb(7) = 500 pointsb(8) = 0
set pline2 = thisdrawing.modelspace. addpolyline(pointsb)
I would like to get a 3rd date from the union of 2 (like the one I get
with edit polylinea > join by acad)
I've tried all kinds of things.
count = application.activedocument.modelspace.count
set pline3 = autocad.application.activedocument.modelspace.item (count - 1)
but nothing to do my 2 pcs are always divided
Sorry again for the banal call but bah! :confused:
Where are you going?
Thank you in advance.
If you have the carriers containing the coordinates of both polylines you only need to create an additional carrier that contains the data of the first polyline and to follow those of the second.
dim pointsa(8) as double
created
dim pointsc(8+9) as double
Then
index = 0
for i=0 to 8
pointsc(s)=pointsa(index)
index = index +
next i
index = 0
for i=9 to 17
pointsc(s)=pointsb(index)
index = index +
next i
at this point you have joined the contents of the 2 carriers
set pline3 = thisdrawing.modelspace. addpolyline(pointsc)
bye
tnx rpor66
It was exactly the tip I needed,:finger:
now I proceed to the reverse:
if I create a poly make a mirror on the same
ex [Set mirrorObj = plineObj.Mirror(XY1, XY2)]then join the 2 I try to extrapolate the cordinates from the poly mirrorobj
and redesign an object as in your suggestion
I'll have something to have fun.
Thank you again
