Try to look up www.3dcontentcentral.comuse solidworks not? to make the asses of that joint it takes less than 10 minutes; see if it's worth losing time looking for something that will never have the measures you need.I would like to know if you have a drawing (messa in tavola or 3d) of a joint type what I attached to you (page 1).I have to import it on ansys.
I think you're falling ill. If you don't know the producer, there's no such thing here special. let the brand and the model say, then ask the company politely to send you the step and you work there quiet and peaceful:finger:I would like to know if you have a drawing (messa in tavola or 3d) of a joint type what I attached to you (page 1).I have to import it on ansys.
cylindrical hinge: see the doors or gates.... there is nothing to invent :biggrin: or is it something special already here?we start from the first point: how to create a cylindrical hinge?
simply because in English film pairs are also called joint...ok nothing easier, goodbut why does he call me joint that kind of pin?mah.joint not mean arrived?
depends on the pairs in play. if you have to/should use a reducer use the epicycloid axial ones. ..look on the alpha site reducers. they cost a bang but they have zero game, as indicated by them.then I think I understand, basically I use a clutch joint and connect the link with the discs.ok this seems solved.I wanted to ask you something: according to you it is appropriate to use a reducer? the engine should be a step by step
on a robot axis? No idea. They have a huge game.I would put an end-ruote screw reducerso I don't need a joint and I have high pairs!
