knowledge-parametri-iris dome
  • Thread starter Thread starter alpole
alpole
sending a small example of the use of
parameters and formulas, in the panelling of surfaces;
in this case, a semi-spherical dome changes its opening
I would like to thank the rapporteur for his work.
the diaphragm in a camera-
to create variations go on the node parameters
and change one of the following parameters:
1- radius of the semisphere
2- diameter of iris (top opening)
3- ngon, or polygon of paneling
of the surface
the result, albeit obtained with minimum "stresses ",
I think it's important. good deepening
to the
I opened the file with my hd2 but I don't see the parameter package and relations. What license did you use? Can I do it with mine?
thanks in advance.marco
Maraca
the file I created using the module
generating shape design
you must have in the worbench between the tools
the real icons to knowledge, from how much
are available tools
also in the form part design-
to the
Have you set the set display in the tree in option?
Thanks, guys. Tomorrow morning, in the office, I verify.
Bye. I don't know why, but as I said, I don't see the parameters. I have special licenses set according to specific customer catsetting.
an additional question: can you generate a catpart with the integrated table (no xls/openoffice external file) that you can manage in assembly without changing the catpart? I've got anti-virus issues driving, and I can't use it.
I'm spulning more than I can the blog.
Thank you very much for your help
you can do it.
you need to create a side template
which contains within the parameters,
tied to a table, if you want..., then upload this part to an assembly,
changing the parameters of the part loaded in assembly, you will see that
those of the "source" part are unchanged
to the
thanks to thepole.
You're the ones who help me. today the pc also crashes with the screen saver:-(
I'll be able to give you a try.
branded
If you want to make parameters appear in the logical tree you have to set the option in settings. search the forum last week
