known with configuration
  • Thread starter Thread starter mohammed.majdouli
mohammed.majdouli
Good morning, everyone.
when I run a note and I tie it to the date configuration gives me the current date and goes fishing deducted from windows.
well if I want to create a date configuration by adding 10 more days? is it possible?
example an order to forn. external external
normal date I leave in the cartiglio
delivery date + 10 I put it as note or top or bottom
what you insert is not a note related to a configuration, but to a variable. configurations are anything else.
the date can be that of creation or rescue.
I don't think it's possible
Yes, yes, my mistake
and a note related to the date property
but since the given property is editable
I wondered if it was possible to create a property where I put myself on
of delivery varying the string that proposes you with one that counts me 10 days ahead
the date property is editable
in what way editable? from where do you get this date?
could be a manageable thing with tab builder and excel files, but it's an idea to check out
the date as you say and a variable ok
but if I have the possibility to create a property as it seems to me
and the property linked to the date and editable
then I cover the string that as a result gives you the date and I do not know I apply a function that gives me a result more 10
the date I take it by applying note linked to the solid property that already gives you as default
you wrote that the date is editable.
editable means that you can change it voluntarily.
if you recover the date through the variables listed these cannot be edited because related to the date of creation or saving that are system property (the ones you see also making properties on the windows file)
if you manage the date as a written property manually then the situation is different and requires a different approach.
then explains well what you mean by editable date
Yes by editable I mean that the string that refers to the date and possible write it manually then I deduce that if there is a string that it is possible to write manually I wonder if it is possible to apply an additional function or string to what gives you solid already that leads me to 10 days ahead a little as in exel (example attached )
Can I tie it to an exel or tap builder?
I apologize if sometimes I express myself to gestures even in front of a keyboard and you do not understand
an example of how the delivery date should work with exel
Extection of exel not eligible in this forum
Anyway and simple and I think you know better than me
date today xx/xx/xxx
working days xx
result = excludes Saturday and Sunday counting 10 days from today's date = xx/xx/xxx
but I don't care that maybe you take me Saturday and Sunday maybe and ask too much
but if it is possible only to count the 10 days
the date of your image in post #5 is not editable because it recalls a variable managed by the operating system.
any file of which there is no extension should be attached zipped
the tab builder is a system to insert properties within files.
you can set the properties as a list, linked to the file variables (mass, material, date...) and also to an external excel file. see second imageImmagine.webp
