known with parameters on set
  • Thread starter Thread starter 3dxx
3dxx
I want to put notes connected to parameters on a board.
the note that I want to put must recall a parameter of the component and not to the axieme, a method that I could use would be to impose the active component every time I have to put the note, but if I assimilate with many components it becomes a very long thing.
Is there a simpler way to connect it?
Bye.
try to do this:
in the relationships of the assembly create a xxx parameter, which then you will recall in the note of the table, to give it the value of the parameter of the part contained in the together the instructions are:
xxx= then select enter> from list>cerca in>parte click on part
you present the parameters of the part, select what you want
insrisci selection and in the new parameter in the set you will find its value
I managed on a component.
I thought it was easier:biggrin:
but then to make my note on all the components that have different code, do I have to make a relationship for everyone?
example xxx, xxx1, xxx2 and so on?
If I have a 50-component set, should I have 50 relationships?
Yes, I don't know other systems, to insert the parameters in the notes.
However if the details you need to know about are so many I suggest you use a table, this way is much faster and you don't have to worry if the components increase or decrease
I think I do first, I put the table and the related bubbles I make before.
I thank you for your help.
