label traduzione
  • Thread starter Thread starter ale152
ale152
Hello, everyone.
I have a problem with my copy in Italian of catia v5.
inside the sketcher (and maybe even somewhere else, I did not notice) there are some labels that were not translated. the problem is that they are not even in English, but they appear strangely:
the problem arises when these labels are particularly long, as in the case of the fitting. if I hit the sketcher tools on a bar, the labels are so long that they don't come in all! then I have to reduce them to a window to use them, and it is extremely uncomfortable.
Is there any way to solve this?
I don't understand, are catsettings not catia settings? What is there from installer?
around I found some guides for catsettings, but they say just how to export/import settings. . .
Shut up.
delete the catsettings folder.
throw catia (if you recreate them yourself).
icons will appear.
You probably didn't erase them all.
Somewhere you still have catsettings that can affect those phenomena.
or the installation of cv5 is not correct....
it may also be that a variable in the catenv is not set correctly.
after correcting the problem was solved.
you have to see what the variable to correct....
