elleci
Hello everyone,
as from title they are struggling with the sw modeling of a support for a work lamp.
As for modeling with simple extrusion functions I have had no particular difficulties, so I propose the file to have your opinion.
the question that I now ask myself is: observing that piece (considering that it can be destined for a production in series) is possible that it is realized starting from a sheet? I tried to model it using the function sw sheet but I lock myself when I have to make the two side flanges and I also have difficulty to realize that cylinder cable as a single base flange (from the well understood file that I have two pieces actually separated).
Surely the solution will be quite simple but I can't come to the end.. .
I put the file I'm working on here.
do you have any suggestions / advice to give me?
p.s. I did the tutorials of sw and bed sheet in the help the ability to merge the solids but so doing then I have problems in extending the obtained solid
