lamp in table holes
  • Thread starter Thread starter DANI-3D
DANI-3D
Good day to all.
the diameter and depth of the lamatures in the standard holes iso I have always added them by hand during the definition of the hole, I saw that there are the variables cborediam and cboredepth that control the dimensions of the lamature.
I made a copy of the iso.hol file, I called it ison.hol, to make a test I left only the rows relative to m10 holes, and I added the two columns, but the new file is not loaded at the start of pro-e.
Where is it?
Thank you, very kind as usual.
Your table works perfectly, but out of curiosity, do you understand why mine is not loaded?
Hello, Lollone,
starting from your holes I made a single iso.hol that contains:
threaded holes
Laminated holes
upper and lower flaws
see if you can be useful
but the values of the devasations you put serve to smooth the hole?
I the table of the holes flaunted the use for the locations of the screws to the head ribbed...cmq the file table seems great!! !
to me the file hole ison is loaded.
Have you tried charging pro-e?
I also remember that to be loaded the file name.hol must be equal to the thread_series parameter (but that is right)
there was then a rule on the maximum length of the file name (also this is appropriate).
The flaws I have inserted are actually 0.5 mm bevels that can be represented at the beginning and end of the threaded hole to raise the suppliers to lower the threaded holes.
the ison file can't load it in any way, so I left it
I think you did a good job with the new one.
I associate myself with compliments
I would like to ask you what the measure of the bevel on the thread depends on, in fact it happens to me that selected a thread if active only the bevel this takes the measure set in the hol file while if I add the lamatura the measure of the bevel assumes a value that is not found in the table
example m3 bevelous 3.5 bevel with lamatura 4.25
thanks to the compliments, but I don't know where that 4.25 comes from, however the top bevel in the case of a lamatura does not need, at most you can use the lower one
Hello everyone
I'm new to the forum, even if I've been following you for a while.
I've been working on casket for several years, first 4 and then 5.
My question is the following, is there a way to create a table in order to match a diameter of voro a possible lamatura?
Let me explain better, diamet hole 14 for m12 screw and lamatura diameter 20 depth 14?
thanks to all
Hello everyone
thanks to all
Is the question on casket or creo?
This is the creo section, if you're wrong, tell me that I'll move the question to the relevant section.
