launch a .bat file from autolisp
  • Thread starter Thread starter x11start
x11start
stó doing a lisp that needs to read the data produced by a file with the Bat extension.
the file that I will read is a simple text file, but it will be the .bat (to be launched at the same time at the lisp) to create it.
Is it possible?
I found the answer:
(command "_shell" "type" "fileditesto.txt")
equates to launch the type command and display the fileditesto.txt text
Similarly you can run all dos commands or launch .bat files
