launch more analysis together
  • Thread starter Thread starter stef_design
stef_design
hi guys, how do I run more tests together.
If I have two open mechanics, of which one with the analysis started, if I try to launch an analysis on the other dm comes out the writing:
read-only configuration
the shared license is currently not available for this application
1 license = 1 process
means that the first process gets the license you have and you can only wait. read only is to tell you that you can only read files if the license is busy.
If you don't have a license server, the same thing happens: read only!
hi gerod, if I want to run two tests together, then do I have two licenses? So I have to pay another license?!? .
There's no such thing as a trick. It seems very restrictive. :
