lavorare con solidworks 2005 e solidworks 2010
  • Thread starter Thread starter angelogianni08
angelogianni08
Sorry about the new thread but I also have this problem... collaborating with other people I saw that they have solidworks 2005 while I on 2010... the problem is that obviously it does not open the files of 2010...
I was wondering if my employees can't import the functions no matter, but the important thing is that they can import the parts
I thought about the sat file... I have seen that it is a unique object.. .
but then will they be able to share it and make the table? ?
the sat should work well knows swx to swx since acis is a dassault format. in theory the "official" interchange format is the step, try with both!
edit: but is the right section? we talk about swx
In theory, the best format is parasolid (x_t), if swx 2005 already used this kernel.
Hi, the step is fine, you can share it quietly. . But you do not have the classic functions of solidworks
solidworks has always been based on parasolid. This format guarantees you the best results in export, import and size of generated interchange files.
will be able to make the boards with 2005 but the parasolids will all be "imported" and therefore you will lose the features, the couplings in the assemblies and the graphics.
