lavorare logo
  • Thread starter Thread starter kionn
kionn
I have a new help problem. ...
I must carry out a processing on a sheet.. .
A logo...
how do I upload the .jpg file
on the particular to carry out the path cam?
use pro_e w 3
Don't you have the logo dwg\dxf?
If so, I think you'd better recreate it and import it.
explains what you want to get.
So I have the .dwg now how do I create the solid?
I have to do a milling process on an iron and get the logo out.
then first you should tell us whether the logo consists of a text or a custom logo style. in short the logo you have as it is?
useful would see it, maybe post it so it is easier to tell you what to do!
In fact you are right sorry:
and a design that I don't yet just give me the file put online.
Hello excuse me but I can't post the file because it's a registered trademark.
I have the file in .dxf how do I create a sketch on pro. w3?
first you need to import the .dxf file "insert -> shared data -> from the file" then create a sketch and with the command "create entity from the edge" select your imported logo (loop or individual entities) exit from the sketch, then the sketch you created can extrude it or use it with "modifica -> offset -> deformity" select the sketch you created and use it
p.s.
attention the .dxf file must have maximum precision or in the "create entity from the edge" command the entities will be detached
Sorry about my ignorance.. .
once imported the .dxf file I create the sketch and then to create entities from the edge where I find the command?
inside the sketch in the right menu (try has to pass us over with the mouse and will give you the context menu)
But don't even slide on the sketch toolbar?
Come on.
wanting you can import the dxf directly into sketch environment, but many times if the profile "is not clean" the extrusion operation fails.
if I don't remember badly in sketch environment of can import .dwg and .ai files (you have the advantage that you can edit them while the .dxf being imported as a solid entity you can only copy it giving it an offset or not, but if the logo is a complex little bit becomes a business to manage it, I believe because of the parameterity)
