learn pro-e
  • Thread starter Thread starter grandepuffo
grandepuffo
I need urgently to learn as soon as possible to use the pro-e. :confused: I ask you to give me a valid and effective advice, because I have little time and it is vital for a job that I have received
from which level do you leave?
Have you ever used a 3d cad?
If you don't have any experience, I think you have to look for someone who gives you the first basics.
search for some tutorials si internet.
look, I have to say that I know well inventor, I have an infarination of unigrafix, and the bases (but proper bases) of catia, also I know well the 3d of autocad; So I know what we're talking about. If you can help me? I have a lot of time
Just as long.
the fact of knowing other cad 3d is of help.
starts from the internal tutorial (the one of the modeling of the mobile phone) that teaches you the basics of modeling, assembly, and table setting.
What is the version you will need to use?
max quoto, do some tutorials, if you can use other cads you are already a step forward, even "intuition" you might understand enough to move the first steps.
I'd give you free lessons. proe is the only thing that gives me satisfaction. compliments to the software, but I'm definitely not enjoying existence.
look, if you have the basics of cad3d is not so difficult, even because the software is only a means, the rest is in the head and waits to be modeled. If I were in your side, I wouldn't put anything on it since I was able to take courses when I was working in the old company, I've always been using it. with catia I was operating in a week and competitive in a month, now I'm learning nx, I'm tired of changing software also because when you drove a ferrari or climb on a panda. If you have the chance to reverse eng, i.e. give a friend or someone a nice assembly to study.
I share, I also started with the mobile tutorial and I have to say that it is very helpful to understand how to work proes.
but the only way to start really understanding something is to work on it: So, if you say you're not at zero cad, you start with the job you have to do....as long as you have to remodel some parts because on the way you realize you haven't followed the best path, you'll gain more familiarity than you imagine, not to mention that if you use the search here on the forum, you'll find a great deal of information coming from "the battlefield", that no guide or tutorial can ever replace.
Good job! :finger:
You guys put the wildfire on the table, you're giving me some thoughts. :confused:
Once I insert a component with various views and quotas, I should insert a new sheet, make it the first of the list and insert the explosive axieme.
but then click on change the item "ownership" is disabled.
Why?
Help me, I've been alone today.
otherwise send me, if possible, the procedure of placing the table or where I can reply.
I use wf3, I don't know which version you use, but I think the procedure is the same.
to insert a new sheet, go to insert => sheet.
to move the active sheet, go to edit => moves sheet, and decide the sequence.
to insert the axieme (or another component) in the same design (which I think is not entirely correct, but it is obvious that every way of working is respectable and dictated by the specific needs of each), go to file => properties (or right click on the worksheet => properties) => design models => add model. This is because your .drw is linked to the first component you have entered and listed, and if you want to tie it to other components you must first indicate them. pro/e automatically activates the last added model. from this moment any information will concern the latter. to return to activate another component related to the design, from the design template menu => model set.
for the explosive axieme, you must have created it first in 3d, after which you call it in the drawing from the window property of the view.
As for the disabled "properties" item, I didn't understand.. .
I sincerely find this whole discussion ridiculous, indeed if I were a moderator the eliminers as well.
I'm sorry to be a moralist, but it doesn't seem right to me. .
phrases like:
I have really little time, help me I was left alone today, send me procedures, I am quite allied...:frown:
