length
  • Thread starter Thread starter stefanoart
stefanoart
Good morning to all,
is it possible with r4set the length of a curve (closed or open), already existing?
with the command "analyze -> length" I know the length, I need to vary it, as with 3d scale (in which I choose the direction), but on the command line insert directly the desired measure. .
I was a little twisted. I hope someone can give me suggestions.
there is the _extend command that allows you to extend a curve in many ways, even giving a quota. do some tests:
Sorry, but I just read now...
thanks for the advice, I will try the recommended commands.
Hi, I tried curve change with constant length, but it doesn't happen to me. I did not find extender, in Italian stretch curve there is only relative to the surfaces.
if you type _extend works... (with the "_" in front you use commands in the original language whatever the location of rhino)
in the help you should find a translation of Italian/English commands
try: No, that's not what I was looking for.
I would need a command that deforms the curve (from the center, or from the ends), according to a measure that I decide. I tried to download iol edit box, approaches, but it is not yet so.
