3d device
name : nvidia geforce 6600 gt
manufacturer : nvidia
chip set : geforce 6600 gt
memory : 256.0 mb
driver : 6.14.0013.681
your machine contains a 3d device that is not certified.
as more graphics cards and 3d display drivers are tested, they are added to a list on the autodesk website.
you can check for updates and download the latest certification list at any time. run the 3dconfig command and click the check for updates button.
current application driver: acaddm10.hdi
current effect status:
enhanced 3d performance: available and on
smooth display: available and off
gooch shader: available and using hardware
per-pixel lighting: available and on
full-shadow display: available and on
texture compression: available and on
advanced material effects: available and on
available application drivers and effect support:
software driver
effect support:
enhanced 3d performance: not applicable
smooth display: not applicable
gooch shader: software emulation only
per-pixel lighting: not applicable
full-shadow display: not applicable
texture compression: not applicable
advanced material effects: not applicable
autodesk driver: not certified
effect support:
disable hardware allergy (Nvidia gives trouble to die).
check if you have in those hidden "sweet" dwg.
sometimes there are nested blocks to die, null texts, solid modeling residues also not coming from acad... all things that you don't see video but that acad must recalculate.
Man, you opened a mod! I didn't know that they were troubled in my ignorance I thought the enabled hardware was better because the processor works less! drivers are quite up-to-date and I don't think the last of 2013 solve or not? Anyway, he's got it sung if I zoom a lot and then I'm gonna do the regen.
