Massimo694
Hi, as an examination project I was required to design a gearbox assigned power and engine speed. I would like to realize the least expensive reducer possible, could you recommend the least expensive material for making it, or could you recommend the most reliable catalogs? (indicatively the minimum hardness that I need for the realization of toothed wheels is 460hb but I'm sure I can lower it further in case there is a convenient material)
