levels
  • Thread starter Thread starter CAROLINA
CAROLINA
Good morning.
I have a problem I happened in a project to build first the state of project and then the state of fact.
with different levels.
now for example I have the first_ sf plan which seems to be drawn on the level of the first_ sp plan as from attached images.
in the properties of the view in extensions- I have the flat level first_ sp fixed and I can not change it, so as in the viewing range I have cutting plan set to plan first_ sp.
someone can help me to change these two settings.
I hope to have been clear thanks and a thousand
carolina
you have to create the views of the plant combined with the level of the factual state. You obviously just duplicated them from the sp and changed the work phase
but now that I have already done this and I have already drawn the factual state as I can do? ? ?
or I must perforza create new views of the plant combined with the state of fact and redesign all the state of fact.
carolina
What do you mean you "disegulated" the state of fact? Don't you have the 3d model of the state of fact?
I have the 3d of the factual state, but drawn up here levels of the state of design that I simply duplicated and in which I only changed the phase of work. as I can do now in practice so as not to have to redesign all the state of fact....thanks and a thousand
as already suggested, creates views of the factual state starting from the appropriate levels. I don't understand what the difficulty is. . .
I think that the error could be that carolina changed the factual state, "drawing" in that view (de fact), instead of making changes in another view, the de project?
