library components between inventor versions
  • Thread starter Thread starter costruzione3d
costruzione3d
Good day to all!
for convenience use screw bolts etc... the various components of the inventor's library.
step from 2014 to 2017.
the problem and that all the components used in 2014 is not recognized in 2017 and 2017 tells me that the axieme is incomplete. .
How can I solve this?
Thank you in advance!
in the project file you have to point the cc libraries to the folder where you have the previous ones.
of course you will lose any updates that were between 2014 and 2017.
I figured... So I guess the best solution is to always codify everything.. or are there any other roads?
you could create a custom library, whenever you upload anything from the cc flag on "as personalized" and save it as you want.
then at every new release, point to the custom library.
Yeah, I was thinking about that.
and that by doing so you lose the speed to change to the flight the properties.. but it is also true that you can replace it with a click..
Thank you!
with a library managed well by the pdm, if you codify and save in its path example a screw m8x60 ,
the time after you use the same screw from the library (also understood as material..) the pdm before making it recreate, check if
is already existing and therefore already saved-coded and does not create a new one every time but automatically uses your
. always if you have a good pdm system for managing files.... you automate all the process to the great!!
Forgive me for the delay but I didn't get the notification mail. .
I actually manage everything.. But I miss what you mean by pmd.. Could you be more precise?
pdm = document manager
If you have so many files and many projects, customers etc. with 3d you can't rely on the windows file-system to organize the work
Okay, I'll let you know, and then I'll give you a fix.
for the moment I have a unique library and I co-dise the files progressively. . .
