libreria features
  • Thread starter Thread starter cimaguy
cimaguy
Hello.
I have a question from "neophyte": Suppose I saved a pair of features, in my case an extruded cut of a hole and a curved repetition with a .I also inserted names to quotas and variables.
when I go to reuse these features in a new part, should the same variables or the same names I assigned in the source file be present? ...I hope I've been clear... thank you
I have never created library functions with variables, but in theory if variables are related to functions are imported into the new part.
try and let us know
Thanks for the answer.so, after several attempts, I managed to reuse my guided repetition (commanded by an equation) on a new part, only by exporting the equation from the source file (in txt) and then import it into the new part file. Basically, what I wanted to get was a function that would change the number of instances (in my case of the only hole) to vary.
you can insert in the library function a construction line that has the length of the edge as size.
the portion of the line, which you will use in the equation, can be managed at the time of inserting the library function: by inserting directly the value equal to the edge, or by binding the line and using a guided quota.
I tried. the problem is that when the feature amount, the system does not recalculate the number of instances in the guided repetition, but proposes the result of the equation obtained in the source file.
Let's start from the beginning.
Why do you use a curved repetition and not a linear repetition?
What version of solid do you have? write it in profile thanks?
attach the file so that you do not have to recreate the functions with parameters other than yours
Did you do a ctrl+q? to update the part?
made a flight test and it works.
Of course I don't know what your exact needs are, but as you see on the side on which I entered the library function by changing the share of the basic extrusion the holes fit
Thank you so much.I will update my profile as soon as possible.I just changed work and in the new company have solidworks 2020.
OK thank you very much. Today I compare your equation with mine and see what I have done(y)
I attach the image of the equation I used to share the holes equally and at equal distances from the outside of the profile
