librerie dwg
  • Thread starter Thread starter roccochiolo
roccochiolo
Good morning I need your help, I'll explain to you from import amount the dwg files, but I don't know how to apply it and where you upload it as I should do thanks
greetings rocco chiolo
you do not have to import a dwg. go into the insert > block and in the mask that appears clicks on browse.. .
These are basic commands. I will recommend you, before you get to work, to take a nice course or a sufficiently wide tutorial tour to understand the software, otherwise you will continue to do bullshit
