librerie inventor 2010
  • Thread starter Thread starter design77
design77
After the successful installation of 2010, I find myself with the following problem, the bookcases said center contents, are loaded but remain in read alone.
I can tell you better, but I can't put them in.
in the installation I want to point out that I installed them I do not share them with inventor 2009
aid
inventor's "standard" libraries are read-only, but in the sense that they cannot be changed, not that they cannot be inserted. . .
So, where is the problem, the file is actually read-only, but the fact that it can't fit them?
In fact, it explains step by step what you do and the problems you encounter, so it is easier to help you. . .
So everything and normal active project, I will normally start, new load together, launch the content center select the group that ineressages me, double click but...... as you can see the libraries are obscured and I can't do the usual insertion .
as you see the bookcases have a strange lock......
allego photos
You can see very little, but I'd like to read "the editor of the contained center", so from them the changes and quinids you must first copy in a reading/writing library to edit them, but this regarding the change.. .
for insertion you can also insert those there, but you must use (with that closed window) the command "places from center cntenuti" not "edit etc.... "
In fact, this is the editor to change them, and as these are the standard ones not editable, they are all "locked". . .
Thanks to all, too many interface changes between one version and the other, to me they always send in crisis..........
place here, not to open another discussion. I, always in the context of the content center, published a part .ipt, in a library previously created by the data managment. the problem, yes, that when I go to upload it to another computer (I do not use the vault, and I have no shared folder), once inserted and set on the active project (with configurations library center content), when I go to charge it as "place from center content", I only see the imported library but does not show me the file. I tried to filter, but nothing at all. Where am I wrong?
Hi, I recently installed the 2010 version of inventor, I inadvertently modified the default path that is in:
options -> content center
inventor desktop content, library location
I cannot then upload the content center, I would like to know if you can help me and give me the original default path. :finger:
(not use vault)
Hey, did you mean this route?
c:\documents and settings\all users\dati application\autodesk\inventor 2010\content center\libraries\
:eek:
