librerie vs altro?
  • Thread starter Thread starter MarcoAtk
MarcoAtk
I'm trying to figure out how the sw library works. I never used it, but I think I lost a lot of software.
I would like to have so many instances of the same article, but with different dimensions... I have to use different configurations. or can, for example, make an item of lib. that I will insert into the aid and will have dimens. axbxc while the second instance (which is not a real instance because it has the same caratts. but different sizes) will have dxexf dimens.
etc. .
Am I wrong to use the books?? Is there another way you know, by any chance?
Mar
to have different sizes you need to use different parts or to raise different configurations. How do you define different sizes? How would you select them?
if two details have the same name and the same configuration must be identical, there are no other ways to differentiate them.
I would like, in my group, to have so many instances of the same article but with different dimensions. . .
This is basically the definition of "configuration" so in your case I would say that there is no other way.
I imagined... libraries or not, one part with the same name and same configurations of another is actually equal. . .
I thought I could handle them differently... we say to the "architectural".
insert a basic element is always that and then, instead, at the moment of insertion it is released from "father" and "brothers" and can be managed separately.. .
But it's okay as it is!
