Braga Guest Apr 18, 2014 #1 kindly someone can tell me if and how can you create your own libraries with cocreate 17?
TUAN21 Guest Apr 18, 2014 #2 I could help you with 18. I don't know if there's a lot of difference. However now I try to open the 17th and see if it is similar
TUAN21 Guest Apr 18, 2014 #3 if you also have pm3, from the icon that is bet (see attached image) opens the menu to create libraries then with the template archive command, the archive in the library you want (including your newly created obviously)
Braga Guest May 27, 2014 #4 thanks to all, I am recreating and sharing them in dropbox, of course there is still avalanche of models but over time.. .
