herinfernalmajesty
Good morning to all,
I propose to you the dilemma of the day, I hope to explain the best possible what I can not do
I have to design a system to cut a sheet and paste it perfectly on a complex surface, making the lembi perfectly match, therefore without overlapping nor free spaces.
for this reason I came to mind the function of inventor in which the plates are designed and there is the possibility to create the "flat model".
now I arrive at the question: Is there a way to import files drawn as parts in sheet mode and cut them so that they can be opened as "flat model"? ? ?
I hope I have been clear, I also expect questions of clarification. . .
Thank you very much for your availability. . .
fabiola:wink:
fabiola:wink:
