light bookcase + object
  • Thread starter Thread starter kikko088
kikko088
hi to all, I have a question to do, I tried to download some items to insert in a "project" that I am doing, the problem is that it slows me a bit the pc, a sofa weighs 8mega, if all the objects are so after 4 objects I have 40mega of :frown file: is it normal?
pc I use is quite evolved, quad core, 4gb ram, 1gb video
I also have another question, why if I insert an object this has colors totally different from the image I found on the net?
if saved in pln, the objects remain on the pc and do not weigh on the file. Of course it takes some time to go in 3d.
an 8 mega object is heavy, but depends on who did it. can be found from a few k.
colors are different because likely those are objects made in 3dstudio or other programs. But if the objects are well done, you should be able to change the materials from the settings. however download goodies to import 3ds objects
