light weight and under flexible assemblies
  • Thread starter Thread starter 320i S
320i S
good day to all; I'm going straight to the point:
(solidworks 2016) I have several assemblies with multi-tiered interiors, flexible sub-axis (gas spring for example), but when I open top-level assemblies in light weight mode, flexibility is not inserted and therefore generate errors in constraints, if "resolve" flexible components, everything goes to place immediately.
So I ask: is there any setting that imposes on these under flexible assemblies, to be open always in "resolved" mode, so as not to have to manually search them?
Thank you very much.
It seems to me that it is not possible to identify a precise set to always open in resolved mode.
the same applies to flexible assemblies.
Tonight I try to take a look on the net and see if I find something
I don't know if you'll benefit, but in system options check the spuns you find in the performance card.
that of rebuilding the axieme to the loading should always be up.
