lighten heavy part
  • Thread starter Thread starter mdbosca
mdbosca
hi, I downloaded from the internet a part in step format (it is a video camera for fault detection, small size 60x60x50mm).
the problem is that it is too heavy (18mb) because it is very detailed.
how can I make it lighter? I peed in the f1 but nothing.. .
I tried to create the derived part, but it's worse, it takes me to 19mb.
I ask you only one thing, when you open the part in the browser at the top, is there another manufacturer where with the + open and there is the conversion report?
if you try to delete it, just a short time ago the same thing happened, and eliminating the conversion ratio the file has greatly resized. ...
with inv 2010 there is no command that allows to create "simplified" files to read them. .
at the limit try to make a set, insert your part by simplifying it with the said command (I don't know what it is called, I don't have 2010), then of this together you make a derivative and see how it becomes.
more I don't know how to tell you, I also have commercial parts of 15/20 mb external suppliers that I can't bring down.... .
I also tried to derive from the axieme but nothing to do.
tried also to scourge "reduced memory" has lowered to 13mb, but it must be left the connection with the original part otherwise interrupting it returns to 18mb.
I am convinced that with inv2010 you will be able to delete all the details that make weighting the part (sezionandola, inside I see detailed parts! ! )
the problem is that I have to put a lot in the project and slows me down everything coming to the crash. :rolleyes:
in 2010 you can use the simplified contour function that allows you to create an object made only of visible surfaces (outside) and to stop processing such as holes or other openings. this function is in the assembly environment of the axieme and generates you in ipt derived from the axieme. you can also delete the axieme of origin and interrupt the connection. size is greatly reduced. also browses the news of 2010 together last voice
