lighten revit files
  • Thread starter Thread starter CAROLINA
CAROLINA
I realized the project of a semi-detached house in revit then I covered the roof with 3d tiles as if they were structural elements positioning them as beam systems then I covered some walls with profiles through the extrusion wall command to create a wooden panelling. Now maybe the file is a bit heavy.SH_02.webp Is there a way to lighten it? For example, I should delete on a wall all the wall extrusions that I created only that some can't even select them and then delete them seem blocked.... help or how I can do it.
carolina
sure that not enough a good texture with a bump value a little pushed...... .
However to lighten the file begins with deleting the unused elements from the card you manage....
the large size of the file is given by the tiles in 3d
So that's why the file goes tilt???? I can no longer erase parts of wall extrusion are as blocked and not selectable.
- - - updated - - - -
so to solve the problem I should remove 3d tiles.
but these wall extrusions like you did them?
as a loadable or local family? (excluding the extrusion command of the walls otherwise it would be enough to change the type).
to which category do they belong?
I ask you because maybe with an abacus and a filter you can delete them without selecting them. . .
