lightened steps for catalogs
  • Thread starter Thread starter stefanoma
stefanoma
I have to create steps for online catalogs that are simplified, not too detailed.
At the moment I have quite heavy construction assemblies several hundred pieces.
Is there a program to simplify cad models? what is the best way to simplify a constructive step without intervening piece by piece?
thanks to all
I'm sorry.
saves assemblies as parts with external bodies setting. from them saved as step
but without a defeature that simplifies them would not get something very heavy?
In my opinion, you should already have simplified objects on a constructive level.
so you can select on all light configuration and then proceed as suggested by mass
thanks to all, there are not many roads. the ideal would be to predict already simplified configurations. ...
lightened configurations are the best for example to group the screws into a vittery folder and suspend it in a lighter conf. suspend everything at an indicative level does not need.. .
