Emc2
we were migrating the archive drawings on new machines from 2017 to 2018.
opening a 2017 .idw file on 2018 I noticed and made present to the autodesk technician that a visual representation had lost the display of some series of components .
we normally create visual representations on the main axieme using the island command or visibility or removing the visibility to the whole subaxieme and then making visibility to those components that we associate the visual representation by blocking it later.
bhe on 2018 does not work! on the series inserted in the subaxis , if we proceed with this method but it must be obligatory to leave the under together visible and to remove the visibilty to the parts that you do not want in the representation, the problem is that the thing is retroactive and if the old method has been used the open tables will no longer visulizzerà the series compromising the putting into the table.
the representations will all be correct leaving the axieme of which they are visible.
