limits on ansys license
  • Thread starter Thread starter valeriom
valeriom
Bye!
Can someone tell me if it is possible that ansys, given a particular license, put a limit on the number of knots? My model beyond a tot is not calculated, giving me an insufficient memory error, but I do not understand if this is due to the 32-bit machine or the license that is limited.
thanks as usual,
Valuation
that I know there are no limits to the number of nodes for a commercial license.
probably if you work at 32 bits, ansys goes beyond 2 gb of memory occupation (you can see it with any task manager) .
the advice is to switch to 64 bits, alternatively you can use the /3gb flag in boot.ini to allow the locating of more than 2gb to a process/application, but I have never tried.
Bye.
How many elements does the simulation you're trying to do?
I have no limits in commercial versions.
