line fold flat pattern
shizuru88
Hello, everyone!
I created the leg for a tank with the "tramoggia" tool.
when I explain the solid for the flat model and put it on the table not
I can get notes for the fold lines. I imagine why
I did not bend the sheet in the realization. someone can tell me
How to get these notes? or should I attack? xd
put on the table the explained sheet (the folds he does with the hopper command) and you have two possibilities in the annotations:
- use the table command and select the view
- use the fold command (bend), near the hole command and select the desired fold.
Hello, everyone!
the hopper command, like the other analog tools of the sheet module, automatically generates the fold lines and the fold extension lines, you already see them at video when you create the flat model.
when you put a flat model on the table, you only see the fold lines, if you want to have the fold extension lines, you must flag the appropriate box when entering (or changing) the view.
I also happened (also this morning) that does not even table the fold lines.
difficult to understand why, I solved however "simplementing the settings a little.
for example if you go into the sheet rule and change the radius value, returning to the table, the fold lines are there,
Still bringing the fold radius to the usual values, the fold lines at the table remained.
do not ask me why, mysteries of inventor, but so I solved:wink::eek::biggrin:
Thanks, guys. I realized why he didn't give me the fold lines, but only the extension lines. . .because I chose the padding mode, and not "pressed bending machine". >
