line stretch point v5 r19
  • Thread starter Thread starter abc\123
abc\123
hello to all excuse the question I have a 2d representation of a folded tube created by a profile and a director I would like to know how to set the program so that the director on the 2d is represented with a trotto point line thanks
tx dx on the frame of the view go to properties' view and activate the wireframe 3d option by adding the always visible option in the detailing pane
go to 3d and view the director.
by updating the 2d you will see the line and you can change the graphics specifications.
hi ferrezio thank you, but do not have the possibility to have this line of axes held directly on the 2d when for example I create a new view or from the properties by activating the option without going on the 3d? Thank you.
the automatic representation of the axis applies to cylindrical elements that are represented according to the plan of representation of the view.
this is valid even if you create a cilider as the function costs, but if the axis of the cylinder does not pass by the plane, the axis of the cylinder is not represented at the table.
so if your tubes follow a 3d track you will never see the axis eventually you will see the representation only of the axis of straight strokes.
ok, but when I go on the properties of the view and activates the wireframe function always visible even if my coast does not pass from a single floor the system projects on the 2d the generator of the tube only that projects it with an untreated line, because on ug can project lines held directly on the 2d as they are modeled on the 3d while catia seems that it does not? thanks for your availability.
