linear analysis. shape contact?
  • Thread starter Thread starter folle76
folle76
Hello.
I attach two images to show what I want to analyze. bearing system + 2 semi-tastes + cod. the material is linear. I set a symmetry plan to analyze half system (red in the photo) and left play between the stem of the cod and the two semi-tastes. everything else is in contact and becomes contact region. what parameters can I use to shape contact?
I hope I have put the question in the best possible way and thank all those who will have the kindness to answer me. Say hi.
What do you want to simulate?
depending on what you want to see change modeling strategies.
at the base of the cod is applied a load of 2,5 tons. and the bottom of the bearing is bound to the ground. I am interested in analyzing the tensional state of the semiguscio and the cod. I know already that we are in the field of small shifts and that, unless contact tensions, we do not exceed the yield.
Thank you for your help.
