Marco F inox
As I have already told you, in the central part of the double screw, you have to put a little appetizer to rotate it, a nut for a key, practice a hole to insert a plug or buccola zigrinata as from your design or other.Thank you very much. Can the pin have a smooth central part? I would not like to see during rotation.
It is evident that as you lift the structure, the two screws tend to see more and more, you can never hide them completely, unless, as from your figure, revenues the holes, threaded only in depth, size allowing.
