Alessandro.ale
Hello, everyone. just subscribe to the forum. I press that I have little experience with the software sw.
I am designing an optical access (silver + holder of the alloy steel window) to the combustion chamber of a motor. the system is then subjected, for each cycle, to a variable pressure load that lasts a fraction of a second and that has a peak of 50 bar (very lower than the material yielding loads). this load I have inserted it as a function pressure of time, with a lot of time curve and should be applied only once (not repeated, i.e. more cycles over time).
now, which of the linear dynamic and nonlinear dynamic simulations (which in my opinion are the most reliable for this case) reflect more in your opinion the reality?
I started, by curiosity, more simulations:
1) from linear static results were obtained positive results (i.e. optical access would hold the load);
2) dynamic linears: I have turned so many and with mesh more and more accurate and they have given me similar results, different obviously from static simulation (von mises much lower) but still positive.
3) nonlinear dynamics: high simulation time, in some cases they predicted von mises beyond the yield threshold for quartz, with in general values of von mises of 1-2 orders of magnitude higher than those of linear dynamic tests.
the problem is that the only thing that is non-linear is the load, the rest is all linear (material, geometry etc.)
Sorry, maybe I asked more than I could ask. Thank you in advance.
Say hi.
Say hi.
