lisp for dynamic armor
  • Thread starter Thread starter Riccardo Toniutti
Riccardo Toniutti
hello to all, I am rich geometra/designer who for the first time requires your help.
I have been finding a lot of suggestions within the forum for a long time, which have solved a lot of scratches.
I take the opportunity to thank you for the help you have and are giving me to grow in the profession.
said this ... let's go to difficult things (at least for me) ...
situation:
the head wants to speed up the drafting of structural tables without the help of external programs to pay ... basically, click on the carpentry and clak the armor more the explosives ...
as I am a sink, first I tried with creating a dynamic armor block with attributes (apping_marche.dwg)
... na, it's not okay ... let's try again...
I try to split the two. Dynamic armor lock with invisible attributes and brand block. the problem arises now, it would be convenient to have a lisp/macro (any thing) that goes to select my armor lock and automatically insert the stamp of the compiled brand into all its parts (apping_marche_02.dwg)
Of course we accept criticism and advice ... I do not fossilize on this solution, indeed if you have interesting course changes ... well come!
Thanks for the help and I apologize for all the errors contained here and ;)
Good weekend!
situation:
solution: Tell the boss that he wrote a lisp he did.
is theoretically possible, but practically impossible
we approach revit with the rex expansion module (which I would say free is not:smile: )
and then in the armor there are many variables, choices, considerations, opportunities, reasonings of feasibility and/or practicability that one does, that a program that works outside the celebratory neural network, difficult to solve.
the free program that your boss asked you... It's just your job. do you think you have skills so "ther-ther" to be replaced by a lisp routine or a dynamic block?
in your block you can still automate a peline, inserting in the destriction of the total length, a data field total length element.
but what if I want a bar to l? it takes another block.
What if I want a 45°? other block
a boat with 2 45° ? another block
a four-arm bracket? - Two arms with a hat? four arms with a hat?
if you don't draw exclusively simple armor, you will realize that the case is wide, very wide. I would like to thank the rapporteur for his work.
Let's imagine selecting the carpentry and "clack" you have the armor plus the explosions, marked and charted. . .
Let him see what you've accomplished, it's already a good step.
will save you some executive time (until someone who is not you will not put your hands on the drawing and not knowing how to change the blocks will explode you:angry:).
I agree with crystal! look for science fiction solutions at zero cost...and if tomorrow your customers came out with: "Do you design this structure? So much with the pc in a clak you have everything! it's time to end it with a routine and/or app on the forums. little or so the software must be paid!
thanks for the answer =)
in reality everything is born to avoid falling into errors (which reside in my work "manual" and not automatic) and limit, as far as possible, some delicate procedures such as the total length of the iron etc... that you will surely know better than me, since I do not hide drawing of carpenters and xd armours
for my part what I have been able to do, in the sense that I have created only one object that allows to embrace more solutions (ferri a l, a c, brackets, inclined and other that however fall into the limited case of our office) ... but everything was vainized by other problems ... that is my very little knowledge of the programming language.
I asked here to have a return on the road taken and a help on a semi unknown field as lisp and similar ... we say it was the tip of the iceberg of the work carried out ;)
In fact I had already told the boss that it would not be easy to recreate a command only that, with few steps and the slightest effort, to drastically subscribe to the work, I tried to improve the internal routine of the office and just;) then quiet, I took precautions against those who explode things not knowing what are xd
I'm going back to the rocket on what you suggested to me, thank you =) I will make the virtues of the suggestions ... while I keep thinking about something valid that allows me to help me in my work and, why not, my colleagues =)
thanks for the operation =)
I understand what you say, I am sincerely sorry if I transmitted the message of what you want to take advantage of the knowledge of others =(my was just an attempt to understand other things, improve me on new areas and share (for the first time) my doubts and problems.
Hello, a lisp to quote armor needles qui. It's a few years ago and only uses polylines as a representation of the armor, the length is given by a data field. qui a short video showing use.
hello! thank you very much for the link and for the dedicated time =)
