Betoniera
Hello, everyone.
I'm a strutturist.
to calculate the structures both in c.a, and in steel amount the three-dimensional model unifilare (constituted by lines) in my calculation programs.
I need all lines to be broken at intersection points.
I tried to download the pkbreak.lsp program from the site. that program works well only if you break 2 lines with only one intersection point.
if the lines are many, the program does not work and goes even wrong.
I tried repeatedly to put hands on it without being able to fix it or to understand why it is wrong.
in any way the question is:
you have, kindly, a program that breaks lines in intersections.
If it worked for a 3d chassis it would be ideal, but I would also settle for a program that works in 2d i.e. that breaks the lines in the intersection points in the plane.
I found a similar program in arx, but now I use progecad that does not support arx files.
therefore the request is for file lisp.
Thank you in advance for any answers.
Hello, everyone.
I'm a strutturist.
Hello, everyone.
