painaz
Hi, I've been reading the forum for seven years, but I've never posted, so I never showed up.
the cads I used are me10 (stepping, but unusable without heavy customizations),
solid design, solid edge v16 and v20, proengineeer (the first cad never forgets), autocad 2000 2010.
I needed to reuse the good old but trusted proengineer, version 2000i.
the problem arises from the fact that I have to reconstruct the format with cartilages and I no longer remember what they are
standard parametric notes. on the text "proengineer 2000i^2" of gary lamit I found these:
&dwg_name, also works with 2000i
&scale, also works with 2000i
&format, also works with 2000i
¤t_sheet, also works with 2000i
&total_sheet, also works with 2000i
&linear_tol_0_0, also works with 2000i
&angular_tol_0_0, also works with 2000i
&model, also works with 2000i
does not work on 2000i (not recognized as a parameter to update)
_
I don't remember if there was a parameter for the designer's name,
(maybe yes, on old drawings I had inserted "designer", but I do not remember if as a parameter
or fixed text). almost certainly there is the parametric note for the date (I tried &date but not
The beak!
please, there are some gurus who remember the complete list of standard parametric notes for the 2000 version
to build the carts?
_
The beak!
to build the carts?
