odisseo 18
hi apologies if I ask for your opinion, the question for you is certainly trivial I would just like to know if it was possible how much a box of 80x80x3 mm high 3 meters can be loaded (the pillar according to my empirical calculations should support 2,5 ton, if I have not done wrong calculations) and how much can support a trave ipe from 160 mm in half-work?( according to my calculations always 2,5 ton badly with what configuration? thanks to who will have the patience to answer (I should realize a portal x loft, 3 high 3 high, the putrella the balance of head or coast x have max resistance)?
