load cells and transducers. . .
  • Thread starter Thread starter Jenny...
Jenny...
Hello everyone, I'm new here... I see you write a lot of interesting things. . I am preparing a machine design exam, but I have many, many doubts about the machine that was assigned to me...:confused:
I briefly summarize the "big" problem.. . :
I have to apply to one arm a load cell and a linear transducer. . But materially I don't know how to do... How do I connect them?? ? Am I doing it correctly? ?
I thank you for your help....:mixed:
It depends. for example in the nautical sect (vela) the company b&g provides pins with a load cell inside. But there are others. a simple strain gouge is nothing but a particular electrical wire glued on the detail you need to examine. . .
I give you some details. . .
I chose the cell tc-k1m-f-s of the gefran and the transducer pk-m-0350 always of the gefran...
Thank you!:biggrin:
These are not details.
If we don't know what the specific application is, how can you help?
Can I tell you to put the pk-m-0350 on the threaded pin of the tc-k1m-f-s and then?
Is it possible that one day, and the other, there are such general questions?
apart from the vent, if you apply and explain " d and t a g l i a t a m e n t and " what you want to do, an answer will come.
I'm sorry, but I've never used these forums, for example... It can be that a person can't expose things like this! Your rash can also be accepted, but the fact remains that if you didn't go, you could not answer me... Well, thank you very much. to the next perhaps I will be more clear
Jenny forgives. .
it is not so difficult (and the familiarity with the forums has nothing to do with it).
It would suffice a simple graphic/numerical/dimensional scheme, as you would normally do with any interlocutor to whom I had to present your project. .
What do we know about what you're doing?
and if someone answers you obviously is because you go to do it, but to help you you you have to understand.. and first rule of the designer is to be understood!
this for example:
Are you doing what? ?
Marco:smile:
I will pass through the villain....but these characters that every day show up are just looking for someone who removes the bat without them ignoring an aptitude and as their colleagues say before doing a hand at least prove to have at least lost five minutes to make a sketch.
Guys, you're not bad... you're probably nervous.
I realized that whatever I wrote, it wouldn't have happened well...
I will survive even without your precious advice....
You're hurting her.
if the new users read by reading the simple rules of the forum, they would not take tricks.
reading your first post in fact, you do not understand much what you ask.
Now, if one tells you, he may have some understanding problems. If they tell you in two is already more worrying. But if everyone tells you, they're obviously not the ones in "tort."
then, reset and start again:
Hello, my name is xyz ... study zyx etc. etc. (this is also a sign of education that never hurts). then it explains well what the problem is, perhaps by correcting a simple sketch.
You will see that the forum will help you as it has always done with everyone.
wrong approach.
And if you don't get there, you don't care much.
Good life.
Mar
a good system in the forums is to write the post, go to drink coffee, sit in front of the monitor imagining to be another user and ask yourself "what do I understand what was written? "
if we understand everything, well
If questions arise... Better rewrite!
quoton:smile::smile::smile:
but of the rest, it should be obvious. . .
if in the office, as at school or at home, I arrive from my colleague/friend/parent and tell him
"Listen, I have a transducer and a load cell, how do I put them together? "
It is Lapalissian that arise 500 questions.. .
Since it is not possible to dialogue, on a forum, it is good that things are explained starting from the concept that those who are "of the" do not even know what the topic is. . .
otherwise, once again, it is worth the " meccbell rule"
the forum works as the computer: if you enter munezza comes out munezza, but multiplied by a factor n
therefore content with what has come out, because it is the logical consequence of what you have entered
or jenny has already found alternatively:rolleyes: someone who helps you solve the problem?:biggrin:
