loading error .idw
  • Thread starter Thread starter 86luca86
86luca86
Good morning, I have a problem in creating new tables with inventor; I basically created my custom table with rules and color of the odds at my liking then I saved the model inside templates.. until here everything well, but when I go to create a new table then load my parts to quote I give error "conflict of style" and puts the odds and norms of default..
Is there someone who knows how to eliminate this error?
Thank you in advance! !
ok I try, I usually do this: first of all you should go to "projects", and on the active project enable "reading-writing" in the voice "use bookshelf styles". then open the model created by you in c:\utenti\public\documentipublic\autodesk\inventor\templates, from "editor styles" of the board"management" do all the changes then click on "save style" and "yes all". then save the file/model.... once you open the table you're working on, do "upper styles".
