location command area and log messages
  • Thread starter Thread starter JLeon
JLeon
Hi. .
I have the first verse and I create that of passage from pro and to creo that has still the least pro and...
I wanted to know if the log window could be moved down where it's always been in all pros and...? ?
so also all the menu that opens when you create a feature with the final flag of check for the ok
I hope so thanks
sent by my gt-i9300 with tapatalk 2
create elements/pro 5.0?
I didn't install it, but if it works like wildfire4 you have to press right button on the toolbar, options, and where it says "command frame position" select "under graphic area".
no from the wf5 onwards has been inhibited as a command, it can no longer be done, because it created problems with the new gui.
