Gabriele Anastasi
Thank you, that was the problem.hello check the insertion point of the block.
Thanks, the problem was the point of insertion of the block. I was very helpful.go to page 29 of the attached file, find the answers you need.
Of course using lisp and/or vba the process would be much faster, but since these are not available, in my opinion you could follow a more complex but effective way, create a script, with the help of excel (concatenating the texts of the cells), which inserts all the blocks you need on autocad complete with attributes, perhaps on a dedicated layer.Good morning, I am new to the forum and also a beginner in the use of autocad 2016 lt.
I would need a suggestion from you on an operation that is partly described above.
I need to replace points with blocks that have about 7 attributes each...not only... these attributes should go fishing from a project excel.
Do you think it is possible to do all this with autocad lt or it takes the full version?
Can anyone help me through the process?
Thank you!
the script is a text file that executes the instructions exactly in sequence, where you need to change the extension from "txt" to "scr".Hi.
I understand your conceptual response, but I don't know how to put it into practice. I don't have so much familiarity with scripts. How should I create it? how do I make the various information? Is there a space?
Didn't you think about doing a search? scriptI don't have so much familiarity with scripts. How should I create it? how do I make the various information? Is there a space?
Hi.Hi.
I did research and managed to write it. I have a problem that I can't by-pass and despite looking for no answer. I guess it's trivial, but in the examples I'm looking for, I can't find anything. I figured out how to create it and it works perfectly. Now, since it's a lot of lines, I wanted to predispose them in excel, chaining everything. These are blocks with attributes, each attribute, if I have not understood badly must be preceded by sending. how do I insert the sending in the concatenation formula?
a heartfelt thanks to all
